Activity Forums Adobe Encore DVD Blu-Ray Diagnostics Say OK, But ERROR Message – Someone Translate ?
  • Blu-Ray Diagnostics Say OK, But ERROR Message – Someone Translate ?
    Posted by Dick Osso on September 14, 2016 at 6:56 pm
    Hello
    I’m making 3 Blue Ray disks for a project. I printed disks 1 and 3 and they look fine. I went through Disk two build, ran the diagnostic and there were NO problems, when I tested the DVD with the navigation buttons, NEXT, PREVIOUS, MAIN PAGE…all worked.
    When I hit BUILD for the Image, somewhere inside the build, I get this ERROR MESSAGE:
    Blu-Ray Object Disk 2 Blu-Ray – H.264 for Blu-Ray, Error: “Invalid operation”: Code 19, Note: “Primary video stream attributes must be consistent within playlist”
    I built disk 2 twice, and got the error message. Disk two, I believe, was done the same as 1 and 3 when exported out of X and Compressed.
    Does anyone know where to go to make a fix ? When the diagnostic says nothing more needs fixing, or all the navigation buttons work on preview, I don’t know where to go.
    Any ideas out there ?
    Dick Osso
    Jan Janowski replied 9 years, 8 months ago 2 Members · 1 Reply
  • Jan Janowski
    November 27, 2016 at 12:03 pm
    I had a somewhat similar issue… Diags said fine before burn, but after burn chapters and end actions were ignored on one of multiple menus… Check for my thread above this….
    Re-building menu from scratch (even though it didn’t act up prior to burn) fixed the problem after burn…
