Activity Forums Apple Final Cut Pro Legacy Blu Ray compressor 3.5 mpeg4/h.264 or mpeg-2
  • Blu Ray compressor 3.5 mpeg4/h.264 or mpeg-2
    Posted by Joshua Heater on February 7, 2011 at 9:21 am
    I have clients that want blu ray for their wedding. So I am looking at buying the panasonic bdr206 xl from videoguys. It will hold 128gb but neither mac nor toast has come out with support but it will burn standard blu rays. Is this a good burner. What is everyone using?
    The question for this thread though is this….
    H.264 is a codec of choice for quality over mpeg2 for hd….but is it possible to achieve this with compressor 3.5 and have good results? What bitrate’s do I use(avg and max). I typically have 4-6 videos that add up to 60-90 minutes long. I have not found a work flow for blu ray h.264 for Final Cut users. Or does everyone use mpeg-2. If that is the case what bitrates do you use? I plan on then using toast titanium 10.
    any help would be greatly appreciated.
    Jeff Greenberg replied 15 years, 7 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    February 8, 2011 at 2:45 am
    Stick to h.264s and Apple’s presets are a great way to start. The 128GB? Not needed (and may not work in many Blu Ray players.)
    FCP 7 (really compressor), Encore, Toast will all make blu ray. Higher quality from h.264 over MPEG-2
    Test the presets early to see what sort of quality before you worry about bitrates; your biggest issue isn’t going to be this: it’s going to be if your blanks work in their blu-ray players. It’s only a 60-70% crapshoot (another reason to test early.)
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
