Activity › Forums › DVD Authoring › Blu Ray burners
  • Blu Ray burners
    Posted by Todd Ailts on October 7, 2007 at 7:17 pm
    I am researching Blu Ray burners abd want to use Adobe Encore CS3 on a dual quad core Apple. I am looking for recommendations on a burner for this set-up … my VAR is pushing Lacie $829. Any suggestions or comments or better burners with proven track record in this configuration?
    Thanks.
    Edwin Gendron replied 18 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Max Kovalsky
    October 7, 2007 at 8:11 pm
    We use Lite-On burners almost daily. Have not had any problems with any so far. I believe you can find one online for under $500 these days. It burns 25GB discs at 2x, and Lite-On has promised a firmware update that will enable dual-layer burning, and single-layer at 4x.
    Max
    Author
    Area 4
    New York
  • Todd Ailts
    October 8, 2007 at 11:33 am
    Thank you for your response.
    2 more questions:
    1) Have you found any problems in compatability … with other drives not be able to read the discs you are authoring (as I have read this is one problem, but it could be due to the authoring software – not the burner)
    2) Do you have a vendor you can recommend, especially for reasonably priced discs (I just need single sided, write once media).
    Again thanks
    Todd
  • Max Kovalsky
    October 8, 2007 at 11:51 am
    Todd,
    Like you say, the only issues we’ve encountered have been due to authoring errors. We use Scenarist HDMV, which I believe produces most compliant discs. We haven’t experimented much with Encore or DVDit.
    As far as brands of discs, only top manufacturers are currently making Blu blanks, so you’ll be safe with any on the market. I think you can get Panasonic discs now for under $10. As cheaper no-name brands begin appearing, I would still advise to stick with the big names because one bad disc can potentially cost you a client.
    Max
    Author
    Area 4
    New York
  • Todd Ailts
    October 8, 2007 at 12:05 pm
    Max, Thank you very much for your advice. Todd
  • Thomas Hughes
    October 10, 2007 at 8:26 pm
    Max, Are you authoring on a PC or a Mac? I need a Mac solution. Thank you.
  • Max Kovalsky
    October 11, 2007 at 1:02 pm
    A burner is a burner – it will work on PC or Mac as long as the software recognizes it and Mac Toast should. I’m using PC, however.
    Max
    Author
    New York
    Area4.tv
  • Edwin Gendron
    January 8, 2008 at 4:01 am
    what sort of connection does one of these burners take? all the specs say “SATA” but I have yet to see a “sata” port on any computer.
    perhaps I just haven’t …yet… bc I’m using a powerbook G4?
    Or
    perhaps there is some sort of usable converter to turn either USB or Firewire into a SATA connection???
    any advice? please?
    thank you
    -edg
