Activity › Forums › Adobe Encore DVD › Blu-Ray Burner for Mac?
Posted by Mark Abney on March 16, 2008 at 2:28 amCan anyone suggest a Blu-Ray burner that is compatible with Encore DVD running on a Mac-G5 Octo-Core? I would prefer an internal drive, but external is fine…. I just want to be sure it is compatible with Encore and/or Toast 8. What are you all using out there?
I am setting up a new system and would appreciate any suggestions.
-mark
Mark Abney replied 18 years, 6 months ago 5 Members · 13 Replies -
Graham Jones
March 16, 2008 at 6:29 pmHi,
check out the drive compatibility database at https://forums.xlr8yourmac.com/drivedb/search.drivedb.lasso — I would suggest that that LaCie external burner will probably give you the least trouble.
– G.
Mark Abney
March 17, 2008 at 3:54 pmThanks for the suggestions Graham… I will check out the website.
-mark
Warren Eig
March 17, 2008 at 7:07 pmI’m using a Panasonic SW-5583 internal SATA burner. So far works great.
Warren
Warren Eig
O 310-470-0905email: warren@babyboompictures.com
website: https://www.babyboompictures.comhttps://www.atomfilms.com/af/content/knitwits
https://www.atomfilms.com/film/family_xmas.jsp -
Mark Abney
March 18, 2008 at 1:43 pmThanks Warren.
Just wondering…. are you able to burn successfully directly from Encore? or do you save and ISO file and burn with Toast?
I appreciate any noob tips you might have too, as I am crossing over from DVDSP for Blu-Ray projects.
-mark
Warren Eig
March 18, 2008 at 5:05 pmMark,
I never tried from Encore. I just make a disc image and burn in toast. The advantage to the disc image is I can archive the image and then do multiple burns later.
Warren
Warren Eig
Nick Righton
March 19, 2008 at 2:41 amFYI, Roxio just released Toast 9. It supports Bluray video disc burning now.
I wish I was good at one thing rather than average at many, but oh well.
Dave Jenkins
March 19, 2008 at 5:06 amIf you get an internal drive be prepared for a install that takes a bit of time and pulling apart your mac. It’s not simple. but doable.
Dajen Productions
Santa Barbara, CA
G5 Quad – AJA Kona LHe
Huge 1.2 Raid
FCP 6.0.2-OS X 10.4.11-QT 7.3 -
Warren Eig
March 19, 2008 at 5:27 am[Dave Jenkins] “If you get an internal drive be prepared for a install that takes a bit of time and pulling apart your mac. It’s not simple. but doable.
“Not as hard as you would think. It took about 10 minutes to snake a 24″ SATA cable in my octo to the upper DVD drive bays. I didn’t have to take out the fan.
Warren
Warren Eig
Mark Abney
March 19, 2008 at 1:48 pmLooks like the optical drive is connected via IDE in my new Octo-Core MacPro.
Are you using a SATA card to run your burner?I’ve ordered the FastMac internal IDE tray-loader model and will suffer through the 2x speed for now.
Toast 9 sounds promising too.
So many new toys.
Thanks for all the input!
-mark
Warren Eig
March 19, 2008 at 4:08 pmI hooked up a 24″ SATA cable to the two extra SATA connectors on the logic board of my Octo.
The SATA burner can burn a dual layer a 4x.
Warren
Warren Eig
