Activity Forums Apple Final Cut Pro Legacy blu-ray authoring workflow for Mac: advise please
  • blu-ray authoring workflow for Mac: advise please
    Posted by Dennis Noel gomez on April 24, 2009 at 7:30 am
    Hi all,
    I’m currently trying to research the best way to output blu-ray video through a Macintosh workflow. I’m using FCS 2 and based on what I’ve read, will be purchasing an external firewire blu-ray burner.
    Based from what I’ve been reading in forums, the only way to author blu-ray discs with customized menus is by using Adobe Encore CS4.
    FCS – Encore workflow:
    -from FCP, export using Compressor
    -Compressor exports video file using MPEG-2>Elementary Stream>stream usage:Blu-Ray
    -Compressor exports audio file using Audio>Dolby Digital professional (Auto)>Target System:AC-3
    -Import files in Encore and burn to Blu-ray
    (this workflow came from a blog and I am just referencing it)
    Can anyone suggest a better workflow then this one?
    Any suggestions regarding a reliable external blu-ray burner for Macintosh?
    The link to the above workflow is:
    https://www.videoguys.com/Guide/RE/0xe9e6ee70b14058d398af885beec60b75/Adobe+Encore+CS4+is+the+Only+Blu+ray+Disc+Authoring+Software+for+the+Mac/0xdc0b105356cb732e9cb64143969395ad.aspx
    Thanks for your time.
    Dennis Noel Gomez
    In house video Editor
    FourLeafFilms
    Dennis Noel gomez replied 17 years, 5 months ago 4 Members · 8 Replies
  • 8 Replies
  • Rafael Amador
    April 24, 2009 at 8:48 am
    Hi Dennis,
    Make a search in the forum.
    W. Biscardi explained his workflow just two or three days ago.
    I think is the same than yours, but burning with Toast.
    Rafael
    http://www.nagavideo.com
  • Walter Biscardi
    April 24, 2009 at 11:53 am
    [Dennis Noel Gomez] “Can anyone suggest a better workflow then this one? “
    Encore does not work with anything other than “Play Only” buttons. If you want reliable blu-ray discs with custom menus, purchase DoStudio from NetBlender. In fact they just came out with a full blu-ray workflow that includes an encoder.
    Yep, it runs on Windows, so we have an HP Workstation in our shop just for BluRay Disc.
    Cut in FCP, Export a Self Contained Quicktime Movie, take it to DoStudio for everything else.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Chris Borjis
    April 24, 2009 at 3:49 pm
    for a lower cost option, DVDITPRO HD also produces
    Blu-Ray discs with reliable menu buttons, but
    you have to prepare all assets in advance like DoStudio.
  • Dennis Noel gomez
    April 27, 2009 at 12:37 am
    Thanks for the feedback
    Dennis Noel Gomez
    FourLeafFilms
  • Dennis Noel gomez
    April 27, 2009 at 1:10 am
    Hi Walter,
    Thank you for your quick response, i think for now I will give up on attempting to create fully customized blu-ray discs, mainly because I can’t really afford to spend the amount of time on Encore, having read more posts that seem to point to a conclusion that Encore simply is not a good solution for blu-ray authoring.
    I’ll stick to Mac because I don’t want to invest on a PC system.
    I would like to ask if you would have any suggestions for a reliable external blu-ray firewire burner for Mac systems?
    For now I will simply stick with the blu-ray authoring capability of toast 10, at least until a better blu-ray solutions comes out for Mac.
    Disappointing that FCS still hasn’t said anything about blu-ray authoring.
    Cheers,
    Dennis Noel Gomez
    FourLeafFilms
  • Dennis Noel gomez
    April 27, 2009 at 1:11 am
    Thanks for the suggestion, I’m afraid at the moment I can’t switch to a PC workflow.
    Dennis Noel Gomez
    FourLeafFilms
  • Walter Biscardi
    April 27, 2009 at 10:27 am
    [Dennis Noel Gomez] “I would like to ask if you would have any suggestions for a reliable external blu-ray firewire burner for Mac systems? “
    FastMac.com is where i purchased our internal burner for the Mac Pro, I believe they also sell an external burner.
    As for not being able to afford a PC system, sad to say it only cost me $1,500 for a very high end HP Workstation with 4GB RAM, BluRay Burner and a host of other bells and whistles. It’s quite cheap to set up a Windows workstation these days as those latest PC ads are highlighting.
    A Mac Pro with everything set up the same would have been a minimum $3,500 investment, probably more.
    Read my Blog!
  • Dennis Noel gomez
    April 28, 2009 at 5:52 am
    Great, thanks again for all the helpful info!
    Dennis Noel Gomez
    FourLeafFilms
