Activity Forums Adobe After Effects Blowing out window- what tool?
  • Blowing out window- what tool?
    Posted by Tom Bailey on July 13, 2010 at 10:26 pm
    Hello,
    I’m working on CS3 and I want to make a window appear blown out. Its very close to being blown out but you can see a flag just behind it. The shot is moving and has someone standing in front of the window. using the clone tool came out really messy and varied too much from shot to shot.
    Is there a mask or key that you would recommend?
    Also, if I used the colour effect, can i limit the part of the frame it picks up on as there are highlights on the wrong side of the screen but this might be a useful tool otherwise.
    Tom Bailey replied 16 years, 1 month ago 34,651 Members · 2 Replies
  • Tom Bailey
    July 13, 2010 at 11:25 pm
    Thanks, I will try that. Excuse my ignorance (I’m still learning the software but up against a deadline) but when you adjust a layer does it composite back onto the background automatically (if the composition shows it on the layer above).
    So I would just mask out the area and drop it back on top?
  • Tom Bailey
    July 13, 2010 at 11:39 pm
    ok. but after that it will put itself onto the original image or do i need to press something to recomposite them?
