Activity Forums Apple Final Cut Pro Legacy Blowing in the wind
  • Blowing in the wind
    Posted by William Gaffney on May 29, 2005 at 7:46 pm
    We had some footage shot yesterday on a PD170 and because of the windy conditions the cameraman decided to use an oversize wind shield (a rather nice grey fluffy one). We now have, on some shots, grey fluffy bits visible in the top right hand corner of the frame. Has anyone any suggestions how this could be removed/masked in fcp or should the footage be exported to something more suitable, AE perhaps. Any help for an embarrassed cameraman would be welcome.
    William Gaffney replied 21 years, 3 months ago 3 Members · 4 Replies
  • Will Macneil
    May 29, 2005 at 9:11 pm
    This depends mostly on what’s behind the microphone: overcast sky, no problem, actors face, big problem. Of course you may have the option of masking the top and bottom of the frame if you shot 4:3 for a 16:9 production. Just use the widescreen filter in the matte group.
    For the overcast sky or similar situation, find a suitable bit of footage to cover the offending mic, place on a video track above the mic shot, apply the 8 point garbage mask and draw the mask so as to cover the problem below. Adding the mask feather filter will soften the edges.
    Good luck,
    Will
  • It all depends on the framing and what’s NEAR the “fluffy area”.
    If its mostly a lock-down, you can “Make Freeze-Frame” of the frame when there is no “fur” in it, put the clean freeze on a video track above the moving footage and use the Garbage Matte (or just the “crop”) to mask out the fur area.
    If the image is moving too much for just a few of these freezes to remedy, you could place a copy of the entire same moving footage (synchronized) over itself. On the upper track, “move” it slightly up and to either side of the fuzzy stuff, then crop/matte it just enough to cover the fuzz.
    A last (and highly NOT-recommended) fix is to “zoom-in” the entire image and re-frame it so the fuzz is cropped. This will degrade the entire image so much that it is only a last-resort-gotta-do-it-or-nothing kind of fix.
  • Will, you’re a faster typist than me 😉
  • William Gaffney
    May 30, 2005 at 12:13 am
    Gentlemen, many thanks for the quick reply, the offending item generally has sky or leaves as a background and covers just a small amount of the frame so your suggestions should hopefully get us out of trouble.
