Activity Forums Adobe After Effects blow away cards
  • blow away cards
    Posted by Dawud Ali on April 6, 2011 at 10:23 pm
    hi
    i’ve been trying and still continuing to find tutorials for “blowing away effect”. i could animate each piece but it would turn out very fake and unnatural, thus i be better off not using it
    The scenario:
    i will have about 90-100 piece shaped similar to pack of playing cards. now imagine they have been all been laid down on a surface 10 cards in row, very organised and straight (like a grid structure).
    the blow effect:
    -wind (will be invisible and the) direction will enter from the top and move towards the bottom
    -the wind force light to medium strength, so the cards pieces slide rather than spin and blow away like leaves
    thanks in advance
    Jeremy Allen replied 15 years, 4 months ago 3 Members · 2 Replies
  • Jason Mettler
    April 7, 2011 at 11:34 am
    If you use a particle system like Particular you can apply dynamic effects like wind and turbulance to move the cards however. The trick will be getting them in their initial state. If you can’t manuever that, think about two comps. One of the cards that actually just start disappearing, and the other would be the particle system with the “same” cards blowing away.
  • Jeremy Allen
    April 7, 2011 at 2:50 pm
    You may be able to get the arrangement by using a layer grid as the emitter.
    8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.8
    C4D 11.5
    AE CS5
    FCP 7.0.3
