Activity Forums Maxon Cinema 4D Blotchy Glow Texture Problem
  • Blotchy Glow Texture Problem
    Posted by Pravin Chottera on July 14, 2014 at 6:08 pm
    I’ve created a transparent object with glow that, for some reason, results in these blotches as the object rotates.
    There is transparency with a 1.2 index of refraction, luminance with a gradient, and a glow. The texture is set to UVW mapping with a texture tag. There is also a volumetric light inside each of the three segments of the object.
    Below is a render.
    Any help would be appreciated!
    glow test
    Adam Trachtenberg replied 12 years, 1 month ago 2 Members · 1 Reply
  • Adam Trachtenberg
    July 15, 2014 at 5:04 pm
    Hard to say without seeing the file. First thing I would try would be to eliminate the refraction and see if that’s the problem.
