Activity Forums Adobe After Effects Bloody Text
  • Bloody Text
    Posted by Matthew Materazzi on May 2, 2007 at 10:21 pm
    Hey everyone,
    a little help would be appreciated on this one. I am going for a bloody text look, similar to that in the movie ‘300’ when it opens up, but I want it to look as though the blood is splattering across the screen and the text “War Room” is the result of the splatter. Any tutorials out there? I am familiar with Aharon Robinowitz’s tutorial on bloody dripping text, but that is not what I am after. I want a splash/splatter across the bottom of the screen, with the words War Room splattering along with the run-off excess blood.
    Thanks so much,
    Matt
    Jesus is Lord
    Mizzmeister replied 19 years, 4 months ago 4 Members · 3 Replies
  • Mike Clasby
    May 2, 2007 at 11:34 pm
    I haven’t seen 300 (shameful I know) but you might look at Andrew Blood Splatter here:
    24. Blood Splattering on a Tree! NEW!
    https://www.videocopilot.net/tutorials.html
    Maybe you can sub in some bloody text for the splatters that Andrew uses (or combine that with Aharon’s tut).
  • Matthew Mccarter (macattack)
    May 3, 2007 at 2:52 pm
    Plus, Andrew also has the Riot Gear FX set that has some ink spatters
  • Mizzmeister
    May 3, 2007 at 6:30 pm
    Hey… I spent a few hours one Saturday a couple of weeks ago just spattering sheets of paper with ink. I scanned them in and after using Photoshop to take them out of the paper background imported them into AE (7). If you create a mask that is similar to the shape of your ink spatter, yet smaller, and then animate the mask expansion from a negative value (so that none of the spatter is visible) to a high value (in which all of the spatter is visible), you’ll get the effect of ink – or blood – spattering against a surface. Throw down a grungy-looking font and you’re on your way to a cool looking “300 style” title effect. I’m not sure if this is what your looking for, but you can modify things to better suite your vision…
    Archive contains: Photoshop files + Final AE file
    https://download.yousendit.com/17472073754998A9
    Also if you want some more ink spatter scans just let me know…
    milo@waveslave.net
