Activity Forums Adobe After Effects Blood running down screen fx (a la Bond intros)
  • Blood running down screen fx (a la Bond intros)
    Posted by Majorlance on August 4, 2007 at 10:49 pm
    Hi. I have just started using AE 6.5 today, and I am wondering how one would make transparent blood run down the screen over an image, a la the James Bond intros with the gun barrel. I have come across plenty of tutorials for the gun barrel, but I am more interested in the blood effect right now. Any hints or suggestions would be appreciated. Thanks.
    Worse things have happened to better people…
    Majorlance replied 19 years, 1 month ago 3 Members · 3 Replies
  • Jerzy Drozda jr
    August 5, 2007 at 2:18 am
    It really depends on how real you want this to look. As far as i remember the blood from Bond was just a solid layer running down the screen, so what you can do is simply create a new solid, and animate the mask shape over it.
    Second approach (very simmilar) is to create a solid layer (red of course), then the second one (color doesn’t matter) that is twice as big as your comp, move it up, so the bottom of the layer matches with the bottom of the comp, draw a mask with the shape of the dripping blood you require, animate the mask just a bit, then animate the whole mask layer, and apply its alpha as the alpha matte for the red solid layer.
    You can also animate the red solid layer by using liquify effect (you may know it from photoshop), or use some particles, for example Trapcode Particular, or Particle World / Particle Playground, that is biuld into after effects.
    Good luck.
    maltaannon.com – Free After Effects Video Tutorials and more
  • Scott Mcqueen
    August 5, 2007 at 3:48 am
    Chances are if you have particle world, you have Mercury Man as well, that’s what I would use.
    You make a comp with your blood texture (just a red to scarlet ramp should do it) and then apple Mercury Man with high resistance and low birth size.
    Thanks.
  • Majorlance
    August 5, 2007 at 4:57 am
    Thank you very much, Mr. Maaltannon…that did the trick!
