Activity Forums Adobe After Effects Blood flowing through Arteries Animation
  • Blood flowing through Arteries Animation
    Posted by Josh Branam on May 16, 2005 at 7:38 pm
    Hello Cows,
    I have recently acquired a freelance job in which I need to create a Medical Logo Animation .
    I was going to create the blood simulation in 3D, but because of the deadline I will bang out in AE.
    Here it is:
    – need to create a blood flow, in which I could use the illustrator file of the logo to mask out the circulatory
    system. (I was thinking some sort of fractal noise w/ turbulence).
    – the logo animation will be a simple pull out and reveal, but I need to enphasizes the blood in the arteries as it passes by the camera.
    THX in advance, any approaches to this project are extremely helpful.
    J
    Filip Vandueren replied 21 years, 3 months ago 3 Members · 2 Replies
  • Tim Johnson
    May 16, 2005 at 8:13 pm
    You may want to try the foam plug in. I’ve used it with a flow mask before and it’s worked out pretty well.
    Tim Johnson
    KUTV 2 News
    Salt Lake City, UT
  • Filip Vandueren
    May 16, 2005 at 11:23 pm
    Foam works great, but evenso, here’s another suggestion, depending on the look you’re after, It might give you more control since you can substitute the little white dots with red bloodcells you create in photoshop:
    bubbles
    here’s the thread from last week where you can download the project-file:
    Name: mirek / Date: May 8, 2005 at 10:28 pm / Subject: Desperate animating flow..
