Activity Forums Compression Techniques Blocky color/banding with MPEG2
  • Blocky color/banding with MPEG2
    Posted by Claireystew on April 1, 2006 at 2:42 am
    I’m generating multiplexed MPEG2 in Compression Master at bit rates ranging from 2 to 5 megabits per second. I can’t seem to find the setting to not get noticable blocks and bands of color, mostly in solid backgrounds.
    Original source is dv from a variety of originals (DVD, vhs, minidv, etc.)
    I am deinterlacing, which is introducing a little softness, but otherwise not doing any other image processing.
    I’m seeing something similar whether I use CompressionMaster, Compressor, Cleaner 6 or Cleaner 6.5, which makes me think I’m missing something fundamental.
    Anyone have any ideas?
    Daniel_l replied 20 years, 5 months ago 3 Members · 6 Replies
  • Ed Dooley
    April 1, 2006 at 6:21 pm
    5MBit should look OK, but why are you doing anything at 2? Is your project so long that you need to
    go that low? I don’t know how you wouldn’t get artifacts at that low bit-rate. Without knowing what
    the video looks like (how much detail, like trees, or how much movement) it’s hard to say why it looks blocky,
    but if you have the room on your DVD, you can raise the bit-rate to 6 without any problem. That may help.
    Ed
  • Claireystew
    April 2, 2006 at 4:10 pm
    Thanks, but I’m seeing this at both 2 and 5. I see it even when I up the bit rate beyond 5, in fact.
    This is not a DVD project.
    I’m producing multiplexed MPEG2 for streaming. And it does have to be MPEG. We are using a specific server side technology.
  • Ed Dooley
    April 2, 2006 at 10:44 pm
    Sorry, I guess all I can add is that, although the most recent source is DV, the original source includes
    already compressed MPEG2 files from DVD, VHS (terrible quality to begin with), and possibly even the miniDV
    you’re using was compressed again going from the original to a compilation tape. Compression on top of
    compression doesn’t work too well. It doesn’t sound like higher compression bitrates have helped, but in theory,
    the least amount of recompression will give you the best image.
    Ed
  • Claireystew
    April 3, 2006 at 2:00 am
    Yes, I know all of that, but this is the chain I’m working with and it’s not possible to change the original source. Thanks for that suggestion though.
    I’m trying to make the best of what I’ve got.
    Anyone else about the blocky/banding thing?
  • Ed Dooley
    April 3, 2006 at 2:29 am
    OK, one more thing. I haven’t persoanlly run across this as a big issue on my projects
    originating from Beta-SP or DVCPro50, but there are plenty of suggestions about banding
    with 8bit projects that would suggest the possibility that if you redig the footage as 10bit,
    you may reduce or eliminate the banding part. It probably won’t help the blockiness though.
    Ed
  • Daniel_l
    April 11, 2006 at 11:14 am
    We have a (rather crude) saying over here in the UK.
    ‘You can’t polish a turd* ‘
    * – https://dictionary.reference.com/search?q=turd
    DL
    Video AllSorts
