Activity Forums VEGAS Pro blocky/choppy/vertical lines
  • blocky/choppy/vertical lines
    Posted by Ali Mufti on June 29, 2023 at 10:26 pm
    · Using different cameras all shooting at 60fps 1080hd. Gopro 8, Panasonic hcx900m. canon m50.
    · I edit in vegas 14. Timeline is 24fps, 8 bit setting.
    · Disable resample, best quality, gagassian blur all clicked.
    · Rendering bit rate set at 50million and average at 28million, quality best. Mp4 format.
    · The problem I encounter is that at 23.9,24(film) and 25fps rendered (and preview) video is blocky/choppy on panning shots especially. Still shots and talking to camera is okay.
    · Render (and preview at 50 and 59.9 fps gives me video with vertical lines on panning and movement shots.
    I would like to know how to fix this issue? Please advise
    Thank you
    Ali
    Aivis Zons replied 3 years, 2 months ago 2 Members · 1 Reply
  • Aivis Zons
    June 30, 2023 at 4:33 am
    It would help to see an example with recording & project parameters, but I believe the main problem you’re having here is called video judder.
    That stuttering during pans is particularly noticeable when there are a lot of reference points in your video, no 1 clear focus point for your eye. There’s a lot of parameters that influence how strong the stuttering will be, but the main thing here is panning speed. The slower you go the better the results should be.
    Higher framerate can also help with reducing judder. Comparing 30 to 60 fps – you could safely pan 2x faster in 60fps for example. Shutter speed is also a big factor – try matching it to the framerate.
    You could do some post processing and add motion blur to help blend the judder, but that might also hinder your shots – depends. I wouldn’t recommend this approach though.
    As for the vertical lines… the only vertical line artifacts I can think of would come from GPU driver problems. However, if you meant horizontal lines (interlacing) – that might be from “Field order” in project and/or render settings. Set Field order to “None (progressive scan)” and see if that helps.
