Activity Forums Adobe After Effects blocking reflections
  • blocking reflections
    Posted by Dan Marker on September 10, 2007 at 11:17 pm
    I am working on a composition with a set-up very similar to the one in Andrew Kramer’s reflection tutorial found here
    https://library.creativecow.net/articles/kramer_andrew/reflections.php
    My composition also has a 3D video layer back in z space that reflects onto a floor using Andrew Kramer’s adjustment layer trick [in tutorial] to render the reflection on top of the floor
    Then I have another 3D layer in the front that blocks only part of the back layer… using the adjustment layer reflection trick allows the reflection to continue through the front layer.
    Is there a simple way to have the front layer stop the reflection?
    Roland R. kahlenberg replied 19 years ago 2 Members · 1 Reply
