Activity Forums VEGAS Pro block artifacts on dv tape
  • block artifacts on dv tape
    Posted by Troy Musson on August 25, 2011 at 8:50 am
    Hi everyone
    I have recorded some wedding footage with a minidv camcorder pal interlaced. when playing back the footage on the camcorder i see a lot of square blocks radomley here and there it tends not be so bad as you progress through the tape but is still apparent. I played it on a different camcorder and the artifacts are still there. Now is there anything that can be done to fix this in vegas or any other software. this is obviously been recorded like this. Thanks
    John Rofrano replied 15 years, 1 month ago 2 Members · 1 Reply
  • John Rofrano
    August 25, 2011 at 6:39 pm
    [troy musson] “Now is there anything that can be done to fix this in vegas or any other software. this is obviously been recorded like this.”Not that I know of. It sounds like either your record heads were dirty or you reused a tape (or both). Whatever it was… you’re stuck with it. That is what’s on the tape now.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
