Activity Forums Adobe After Effects block and erase a shape using another shape
  • block and erase a shape using another shape
    Posted by Alex Trimble on March 27, 2014 at 10:33 pm
    This seems like it should be a simple question but I’ve looked for an answer for several hours before posting and couldn’t find anything. I want to create an effect where a shape (letters that I drew in Illustrator, then imported into after effects and traced) appears from the middle of the screen and expands out, then returns to a smaller size. As it expands, I want it to erase/cover several shapes behind it. (This is all just simple shape layers or .png images, no actual filmed footage or anything) I’m not sure if I should use a null object or maybe one of the included effects for this, or some other way?
    I would appreciate any advice on this, thank you!
    Chris Brett replied 12 years, 5 months ago 2 Members · 1 Reply
  • Chris Brett
    March 27, 2014 at 11:50 pm
    Hi Alex
    ——- maybe am not understanding the problem but this is probably fairly straightforward ….
    …… Firstly have the animated letter on a separate layer THEN EITHER:
    ( 1 )—- if the animated letter is physically large enough to entIrely cover the other letter( s ) just make sure its on the top layer ( make disappearing letters transparent when covered if you dont want to see them again )
    or
    ( 2 ) —– if the letter isnt big enough and you want to use it as a ‘wipe’ then set copies of this animating letter as a trackmatte for each of the layer( s ? ) you want to loose – using animated masks to mop up any remaining odds and ends —
    Also
    You can open illustrator vectors in Ae as shapes ( also you can copy and paste Illustrator vectors as paths which can be useful for animations ) .
    Hope this helps –
    – all the best —- chris —
