Activity Forums Apple Final Cut Pro Legacy Bloated render file
  • Bloated render file
    Posted by Ron Pestes on June 15, 2011 at 4:55 pm
    What is the best way to manage the render file. As I get more and more projects done the render file has gotten huge. Since it is kept on my C drive it is getting to the point of being a problem. Is there a way to only keep the final render? I notice that there is a long list in each render file for each project. I have projects on several different external drives so I am not sure what the best strategy is. Also, can I move the parent render file to another drive or will I have to re-link all the projects again? Thanks for any help.
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
    Ron Pestes replied 15 years, 2 months ago 3 Members · 5 Replies
  • Shane Ross
    June 15, 2011 at 5:12 pm
    Keep the render files on the same drive as the MEDIA files. They are, after all, media. And when you are done with a project, delete them.
    Shane
  • David Roth weiss
    June 15, 2011 at 5:16 pm
    [Ron Pestes] “Since it is kept on my C drive it is getting to the point of being a problem.”
    That’s a problem, as it’s a media like any other and should be on your media drive in a best case scenario.
    Meanwhile, use the Render Manager in the Tools menu to delete those renders that you deem no longer useful.
    You can use Media Manager to Copy or Move the entire contents of projects, with their render files, to a new drive. Do keep in mind, the Move feature is destructive, the copy feature is not. However, copy requires that you manually delete your old version of the project once you’re convinced of the integrity of the new project, while Move does the process all at once (at least in theory). Also, both Move and copy place all media in a single file in the location of your choice.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Ron Pestes
    June 15, 2011 at 6:15 pm
    OK. How do I reset my render location? I don’t see it under any of the user preferences or system settings.
    Sony EX-3
    MacBook Pro
  • Shane Ross
    June 15, 2011 at 6:23 pm
    Final Cut Pro menu. SYSTEM SETTINGS. Scratch Disk tab. You set it to the same place as your Media…there are check boxes for media, audio and render files.
    Shane
  • Ron Pestes
    June 15, 2011 at 6:26 pm
    Got it! Thanks, I knew it was in there somewhere.
    Sony EX-3
    MacBook Pro
