Activity Forums Adobe After Effects Expressions Blinking expression for random characters of a text
  • Blinking expression for random characters of a text
    Posted by Sebastien Bruzzo on April 12, 2023 at 8:14 pm
    Hello there !
    On a text layer Animator, I’d like to adapt Dan’s good old blinking effect expression :
    minSeg = 1.5; //minimum interval (must be > 0)
    maxSeg = 2.5; //maximum interval (must be > minSeg)
    minFlicker = .5; //must be less than minSeg
    maxFlicker = 1; // must be less than minSeg
    segStartTime = 0; //initial conditions
    segEndTime = 0;
    i = 1;
    while (time >= segEndTime){
    i += 1;
    seedRandom(i,true);
    segStartTime = segEndTime;
    segEndTime = segEndTime + random(minSeg,maxSeg);
    flickerDur = random(minFlicker,maxFlicker);
    seedRandom(1,false);
    if (time > segEndTime – flickerDur){ random(0,100) }else{ 100 }
    Which, applied to an expression selector with the opacity property, makes the entire text blinking.
    I’d like to have each character blinking randomly.
    The desired effect is that of a neon text whose letters start to blink a little from time to time, randomly. I haven’t been able to find on the forum although I’m pretty that question has been asked already.
    Thank you all !
    Brie Clayton replied 3 years, 4 months ago 3 Members · 5 Replies
  • Dan Ebberts
    April 12, 2023 at 8:40 pm
    If you add an expression selector and delete the range selector, and apply this to expression selector’s Amount property, it might get you close to what you’re after:
    segEndTime = 0;
    i = textIndex*1103;
    i += 1;
    seedRandom(i,true);
    seedRandom(textIndex,false);
    time > segEndTime - flickerDur ? random(0,100) : 100
  • Sebastien Bruzzo
    April 13, 2023 at 8:30 am
    Thank you so much Dan ! It’s perfect.
    Just one more detail, is there a way to invert the result ?
    The current result shows flashing letters from 0% opacity text, and I would like the text to be 100% visible and some letters to go out. Thanks !
  • Dan Ebberts
    April 13, 2023 at 12:59 pm
    You could change the last line to:
    time > segEndTime - flickerDur ? random(0,100) : 0
  • Sebastien Bruzzo
    April 13, 2023 at 1:11 pm
    Oh ! Thanks Dan 😅
  • Brie Clayton
    April 13, 2023 at 7:21 pm
    Thank you, Dan, for providing this solve!
