Activity Forums Maxon Cinema 4D Blinking Christmas Lights with mograph
  • Blinking Christmas Lights with mograph
    Posted by Andrew Riss on November 6, 2013 at 5:14 pm
    I have a border of lights
    I would like to create blinking the way christmas lights work.
    kind of random, but also patterns.
    i have a cloner with 2 different colored bulbs.
    Is there a way to use the formula effector to change the distribution of where the 2 bulbs are?
    any other suggestions for blinking lights would be great
    Andrew Riss replied 12 years, 10 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    November 6, 2013 at 6:19 pm
    It’s certainly possible. Drop both objects in the cloner and then set the Object>Clones parameter from the default Iterate to Sort. Then, in your formula effector, uncheck all the parameters but set the “Modify Clone” parameter to 100%.
    You might also experiment with the Shader and/or Random effectors.
    Example: 6765_christmaslights.c4d.zip
  • Andrew Riss
    November 6, 2013 at 6:31 pm
    perfect that looks great.
    one other question
    for another style, I would like to make a smooth light dark light in luminance
    and have that randomly occur at different times in different places on the cloner
    for the dark bright dark i could either use keyframes or noise, but I’m not sure how to randomize the time and placement of it
    thanks again
