Activity Forums Zaxwerks blending those 3D object nice with your footage
  • blending those 3D object nice with your footage
    Posted by Bart Straman on July 26, 2007 at 4:07 pm
    heey all
    question: i have made two very big sound speakers, were the conus of the speakers react on the beat of the sound, for my videoclip. now if i just put them into my footage it looks very very fake.
    so i wanna blend it, give it some damage, nice cinematic look like my other footage. but how..
    i first though, okey make new layer solid, give all the damage, styles etc to it. parent it to zaxwerk layer(if the object moves) then mask it arround the zaxwark object with pen tool. and change the transfer mode.
    can this be done easier, or better?
    thanxs
    Bart
    Tom Duncan replied 19 years ago 4 Members · 5 Replies
  • Bart Straman
    July 26, 2007 at 6:46 pm
    and ofcourse, i used the layer mapping technic to put a very realistic speaker texture on it. but still it looks fake (to perfect, sharp edges, etc)
    Bart
  • John Drach
    July 27, 2007 at 2:43 pm
    I wonder if you would be able to import that into Photoshop Extended. You would def be able to do that there but I am not sure if it will take a Zaxwerks file. You should show us a link so we can see what those speakers look like. That project sounds cool.
    JOHN D.
  • John Dickinson
    July 27, 2007 at 9:23 pm
    Photoshop Extended won’t accept Zaxwerks files but it will accept an OBJ. There’s no reason why you can’t grunge it up a bit more inside AE – after all it has plenty more tools than Photoshop. In Photoshop Extended you can adjust the colors of the texture maps but it’s pretty limited. I suggest you try some bump maps in Invigorator and perhaps some color correction… but as JOHN D. suggests it would be good to see an image.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Bart Straman
    August 1, 2007 at 10:55 am
    srry guys for the long waiting, been busy these days ^^
    here is a screenshots, it’s just a test, with raw footage and 3D objects.
    https://www.flickr.com/photos/ultimatebart/972449905/
    Greetzz
    Bart
  • Tom Duncan
    August 4, 2007 at 2:19 pm
    I’m not a guru by any means, but it looks fake because of…
    1. Perspective. Try a different camera, larger mm like 35 or 50 or more until the lens matches the one the photo was taken with. The speaker cabinet looks like an extreme fisheye (10-15mm?) was used.
    2. Color and lighting. Maybe desaturate, lower brightness and contrast etc until it matches the photo again. I cant tell if the speaker has a different wood on the front or is it shadowed, but the photo has no shadows like it is overcast (?)
    Hope that helps some or at least provides a start.
    td
