Activity › Forums › Adobe Photoshop › Blending options on CS
Posted by Chris Jilka on July 22, 2005 at 11:07 pmHi, I just started using CS instead of 7, and for some reason every time I try to access the blending options I get the “hand symbol”. Is something terribly different?
Tyler Fuller replied 17 years, 3 months ago 3 Members · 2 Replies -
Richard Harrington
July 27, 2005 at 1:21 pmBlending options are access in the info bar for tools or layers palette for layers…
a shortcut is to select a tool without blending modes *such as marquee, move or hand) then press Shift + or Shift – to cycle modes
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.comedit – produce – direct –
Tyler Fuller
June 18, 2009 at 4:57 pmHi, for some reason unbeknownst to me all blending options stopped working on new images I opened in PS CS. I opened previously edited images that I have put blending options on and they worked fine and I was able to change them. However when I opened a new image after having opened the old image that worked, it failed to insert the blending option I specified. No preview, no blending after I select ok.
Anyone have any suggestions? I have quit PS several times in hopes of resetting whatever is causing it to not work and even rebooted my mac… without success.
–T
