Blending Modes with Multi-pass C4D Output
I’ve exported an animation from Cinema 4d using multipass for import into AE. Here’s the setup for my multi-pass render:
When I open the aec file in after effects, the layers seem to come in as they should. I switched my color space in after effects to linear, to match my c4d output settings. I’m not bothering with any of the lights or cameras from the output–I just want to composite a background into the animation in After Effects. However, my specular, refl, refrac, atmos, and shadow layers all are rendering a black background–even when I have the blending mode switched to Add or Multiply.
I’m pulling my hair out, I’m sure there is a simple setting I’m missing but I can’t figure it out. I’ve opened these layers in photoshop and they seem to render with transparency as they should–however, the black is rendering black in after effects–even when it’s blend mode is set to add. Here’s a screengrab of my composition, with the specular layer soloed, in add mode, rendering black on top of what should be a checkerboard:
Does anyone know what I’m doing wrong?
