Activity Forums Adobe After Effects Blending mode and AI files
  • Blending mode and AI files
    Posted by Yoshiko Tanaka on April 12, 2013 at 11:11 am
    I have a pre-comp with many vector images imported from Adobe Illustrator and I noticed that the blending mode doesn’t work with the pre-comp. Is there any way to use blending more on imported vector images? I’m a making a short animation and all the elements are made in Illustrator and I’m making changes in the vector files and update them as I go so I would like to keep them in the format if possible. Thanks!
    UPDATE:
    Ok, I just found out something interesting/ If I turn off “Continuously Rasterize” option Blending Mode works. “Continuously Rasterize” option with the layers inside the pre-comp makes no difference. Strange…
    y
    John Cuevas replied 13 years, 4 months ago 2 Members · 3 Replies
  • John Cuevas
    April 12, 2013 at 12:49 pm
    This method works.
    Precompose a layer (LAYER > PRECOMPOSE); in the switches column (F4) activate the Collapse Transformations switch (it looks like a little sun) for the new precomp; in the modes column (F4) you’ll notice that the blend mode popup menu has a little dash on it ““ letting you know blend modes are unavailable for the layer. Here’s the trick: Apply an effect to the collapsed precomp (this can be something like EFFECTS > EXPRESSION CONTROLS > ANGLE CONTROL that does nothing) and the blend mode popup will become active again.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Yoshiko Tanaka
    April 12, 2013 at 4:29 pm
    Wow, it worked. Thank you!!
    y
  • John Cuevas
    April 13, 2013 at 2:54 am
    Glad to help.
    Thinkck.com
