Activity › Forums › Adobe After Effects › blending layer is just a dash (-)
  • blending layer is just a dash (-)
    Posted by Eric Bintner on January 27, 2008 at 8:50 pm
    I had a nested composition with the blending mode set to “silhouette luma”. For some reason it has changed itself to a dash (-) and seems to be stuck in an “add” blending mode. If I try to change it it still has the check mark on “silhouette luma” but doesn’t change appearance. I can’t seem to change it at all.
    The layer is not locked. I am using AE 6.5, I’ve been an AE user for 7 years and never encountered this… Help??
    Darby Edelen replied 18 years, 8 months ago 2 Members · 1 Reply
  • Darby Edelen
    January 27, 2008 at 10:36 pm
    It sounds like you enabled the ‘Collapse Transformations/Continuously Rasterize’ switch on the pre-comp. With that switch enabled the layers inside of the pre-comp determine the blending mode.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
