Activity Forums Adobe After Effects Blender OBJ in stardust : all I get is plain colors
  • Blender OBJ in stardust : all I get is plain colors
    Posted by Nicolas Guionnet on April 16, 2019 at 10:00 pm
    I am testing Stardust … and that’s great. But the documentation is not as explicit as it could be …
    I imported an OBJ from Blender. It has 2 materials and the 2 colors appear, but only with an ambient light, and there’s no shadow or reflection.
    I just get plain colors.
    If I switch it to a point light or spot light, the OBJ is black.
    I have been struggling with the options for a few hours and it seems I have tried every possible option in Stardust.
    Any clue ?
    13275_boulesplateau2folder.zip.zip
    Kalleheikki Kannisto replied 7 years, 4 months ago 2 Members · 9 Replies
  • 9 Replies
  • Kalleheikki Kannisto
    April 17, 2019 at 8:47 pm
    If I recall right, it has something to do with the UV mapping selection. Try switching the mapping from the default. Haven’t used Stardust that much yet, but I ran into the same issue and I think it was either changing the mapping or the material that fixed it.
    Senior Graphic Designer
  • Nicolas Guionnet
    April 17, 2019 at 9:51 pm
    Hi Kalleheikki !
    Thank you (once again). Yes, it is the UV mapping. I changed UV Mapping Model to Sphere … Isn’t it weird ? Sphere ?! ????
    For my model is not a sphere but … an OBJ model. I think that, without your help, it would have taken another week for me to find this …
    Before :
    After :
    It is not perfect yet but … there is probably some quality parameter somewhere that I am going to find …
    Great !
  • Nicolas Guionnet
    April 17, 2019 at 9:54 pm
    … I forgot :
    Did you deal with this issue while importing an OBJ from Blender ? … I think you told me you don’t use Blender that much.
    So it’s not a Blender to Stardust problem … rather reassuring for I dread that king of ultra-specific oddities that kill your day …
    April 18, 2019 at 9:29 am
    I use Blender plenty, but I haven’t used the combination of Blender export to Stardust import more than a couple of times. I would expect it to work if the model was exported with UVs from Blender.
  • Nicolas Guionnet
    April 18, 2019 at 10:14 am
    Well, I am going to re-learn Blender. 5 years or more is enough to forget most of what I knew. I will try the export with UV.
    The low quality issue a got (2nd image) was solved when I removed the motion blur option of Stardust.
    April 18, 2019 at 12:52 pm
    On the plus side, Stardust customer support is very responsive. Talked to them plenty this past week. There’s light at the end of the tunnel: They are working on node-specific sample files that (as I understood it) are going to be linked to directly from the manual. So (hopefully soon) it should be easier to learn what the logic behind each node is.
  • Nicolas Guionnet
    April 18, 2019 at 2:13 pm
    Great !
    > “On the plus side, Stardust customer support is very responsive. Talked to them plenty this past week. ”
    Did you use the forum or did you send an email to them directly ? ( I tried the forum a couple of days ago and my post is not published yet … ans some are 8 months old or more and did not get any answer).
  • Nicolas Guionnet
    April 20, 2019 at 4:24 pm
    After 2 days of work in Blender, I believe that importing OBJ’s to AE to use them in Stardust is not as simple as … working with Blender.
    In fact, the last time I used it professionally, it was 10 years ago, and seeing what it became generates a lot of enthusiasm in this room …
    It has everything, and everything is in total control with scripting. For instance, if I want to draw the trajectory of a particle, it’s … easy here, and impossible in Stardust. And, if you have a question … type it in Google … and Bam ! … a page full of answers … It’s not a community, it’s a country.
    Well, let’s compare the next image I created in blender with the ones above in this thread :
    That said, AE is still the way to go for a lot of things …
    I am probably not going to buy Stardust or Trapcode now. Coding vs [ setting a finite number of options ]. Not such a simple choice but for the moment I choose code.
    … but I may change my mind next week … 😀
    April 20, 2019 at 7:07 pm
    I know what you mean. Blender is so powerful today, it makes me question the need for any commercial 3D programs — although I am still considering C4D.
    I haven’t been able to use Stardust for any production purpose as yet. Feels like the program is in some sort of public beta stage. E-mail support is very fast, but that alone doesn’t resolve the need for better documentation. I guess I’ll return to it when the user guide is up to snuff.
