Activity › Forums › Lighting Design › Blend Warm and Cool White
  • Blend Warm and Cool White
    Posted by Pippo Pluto on April 11, 2015 at 6:22 am
    Hi all,
    I’m working with a system where I can dimmer 2 type of lights: Warm White (2600 °K) and a Cool White (8000 °K).
    What I’m tring to do is to find a formula/correlation to calculate the dimmer to apply to each single light to manage different color temperature.
    So far I’m starting from a Temp. (eg 5000 °K). I convert the this to xc and yc coordinates. Then I convert them to XYZ values.
    At this step I know that my two light have xyY coos. What I can mange to dimmer is only the Y component (luminance).
    Does anybody know a way to find the two Y coos to apply to Warm and Cool lights to reach the desired white color temp?
    thanks
    Pippo Pluto replied 11 years, 5 months ago 2 Members · 2 Replies
  • Dennis Size
    April 13, 2015 at 5:24 am
    Can you not afford a color temperature meter?
  • Pippo Pluto
    April 13, 2015 at 6:17 am
    Yes, I can.
    Is what I did so far to understand color coordinates shifts temperature derating of leds.
    My aim is to do an automatic control where I can set a Color Temperature and the algorithm set Warm and Cool to reach the desired temp.
