Activity Forums Adobe Illustrator Blend tool bugs
  • Blend tool bugs
    Posted by Erik Eikeskog on January 16, 2021 at 1:07 pm
    Any idea why this is happening with the blend tool? I have tried different versions of Illustrator too, but still get the same results.
    I have also tried turning off GPU performance, but there’s no difference..
    Is there a fix?
    Picture: https://ibb.co/Hn8ddmC
    Nirali Kothari replied 5 years ago 2 Members · 1 Reply
  • Nirali Kothari
    August 10, 2021 at 2:48 pm
    Some blend tools can create unwanted artefacts in the final design that end up ruining the overall product. For instance, it’s possible for paths to be cut off or appear deformed.
    Blend tool bugs are a common pain point in Illustrator, and they can ruin even the most carefully crafted design. Luckily, there is a way to fix these errors without having to do anything too complicated: just use the “Clear” tool!
    If you’re editing an Illustrator file and suddenly see something out of place on your screen, you may have come across one of these issues:
    – Objects not behaving like they should – Clipping paths being cut off or appearing deformed – Shape fill appearing misaligned.
