Activity › Forums › Adobe After Effects › Blend Text in AFter Effects
Posted by Bob Tanner on November 18, 2011 at 12:41 amI have a clip where people are walking on a court, and I need to blend to the text to the video. Below is a sample of the text.
Thanks in advance,
ZevieSteve Blacker replied 14 years, 10 months ago 4 Members · 7 Replies -
Roland R. kahlenberg
November 18, 2011 at 1:27 amErm, I don’t see any text – all I see is a slightly cracked ground. You will need to provide more images and ALSO to define what you mean by blend.
Cheers
RoRKIntensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer -
Steve Blacker
November 18, 2011 at 1:34 amI don’t see any text sample in that image…
So you just want to place text over the video but have it blend a little? Try using the blending modes on the text layer – you could try Screen, Overlay, Add, among others to get the look you’re after. Sometimes duplicating a layer with a blending mode applied will make it pop a little better.
It’s only work if you’d rather be doing something else…
Bob Tanner
November 18, 2011 at 5:50 am -
Chris Wright
November 18, 2011 at 8:02 ami’d make a luma matte(contrasted with effect-levels) from the existing footage. this will make the ground pop through just like in real life. add, screen, with various opacities etc. if you need tracking, mocha or syntheyes.
Bob Tanner
November 18, 2011 at 8:16 amThe shot is tracked and masked. Do you mind explaining again how to ‘blend the text’, I didn’t really follow… Thanks!
Steve Blacker
November 18, 2011 at 11:22 amI think I see what you’re getting at now – you want to track the text into the footage? Like Chris said, you need to track the footage and apply the tracking data to the text layer, then do a bit of roto I guess. There are lots of tutorials online for tracking (3D and 2D)
Steve Blacker
November 18, 2011 at 1:13 pmI guess I’m not really understanding what you’re trying to achieve. You’ve tracked the text, done your roto.
You want to make the text blend better so it looks like it’s part of the scene? Try playing with some different blending modes on the text (on your text layer there’s a drop-down with blending modes, Add, Screen, Multiply, etc.). If you don’t see it, you may need to toggle (F4) it on.
Other than that, you could play with some colour correction, use some levels/curves/hue and saturation to get the look you want.
