Activity Forums Adobe After Effects Blend modes when using “glow” effect
  • Blend modes when using “glow” effect
    Posted by Keith Carmichael on October 20, 2015 at 4:13 pm
    I’m working on a sci-fi which has glowing billboards. I love the glow effect, my problem is that the “glow” also puts a dark halo around black pixels, even when I set the “glow operation” to Add–I have tried every blend mode for the glow operation. below are my results.
    Right now I’ve just duplicated the layer and set the top layer to Add, which produces a decent result, but I’d like to have more control.
    Any advice or glowing billboard advice in general?
    WITHOUT glow:
    WITH glow (see the “drop shadow” effect where the billboard meets the sky):
    My glow settings:
    Kevin Camp replied 10 years, 11 months ago 3 Members · 2 Replies
  • Cassius Marques
    October 20, 2015 at 6:08 pm
    You’d have more control if you could duplicate the layer where you want to add glow (it should be masked – so that may be a problem). Add the glow effect and set the layer itself to add, black won’t go through.
    On your case, the threshold value should tell the effect which brightness value to glow, increasing it may solve the dark halos.
  • Kevin Camp
    October 20, 2015 at 6:22 pm
    assuming the black framed elements are keyed, you could also try adding cc composite after the glow effect and set ‘composite original’ to ‘stencil alpha’ (essentially re-compositing the original alpha channel after the low effect)
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
