Activity Forums Adobe After Effects Blend ai with video footage
  • Blend ai with video footage
    Posted by Emmet Reddy on August 11, 2024 at 5:13 pm
    Ok im trying to seamless blend between video footage and ai footage. So i have a video with a gopro, swimming under water im creating a freeze of the final frame then im adding ai to this frame, it sort of works, but you can see the cut and the color change, i have tried various transitions to hide the cut i thought of adding bubbles or a fish swimming past to hide the edit, any suggestions appreciated. cut happens around 16 seconds cheers
    Emmet Reddy replied 2 years, 1 month ago 2 Members · 2 Replies
  • Hector Vera
    August 12, 2024 at 4:34 pm
    So basically what you want to do is to make the edit you did at the end of the video to seem natural right? That for the average viewer, it does not obviously look like you transitioned the edit right? Some transitions in Adobe After Effects and in Sony Vegas for example should have an effect to make it seem natural. Perhaps this video I found can give you an idea on what you are looking for: https://www.youtube.com/watch?v=oEF1xhsnsBg Hope it helps in some ways! The transitions needs to have opportunities created so when it transitions from one clip to another, it will seem like you did not noticed it at that moment and it just feels smoother and natural.
  • Emmet Reddy
    August 13, 2024 at 5:29 pm
    Thanks Hector some useful information in there cheers
