Activity Forums VEGAS Pro “Bleeding” an image (?) as a Last Resort
  • “Bleeding” an image (?) as a Last Resort
    Posted by Kelly Griffin on September 28, 2011 at 3:28 am
    Is there a way to take a black still image that’s larger than project settings size and overlay it as a top layer? I’ve still got this recurring issue of underlayers showing through on an upper layer letterbox image, and it’s becoming maddening…
    For example, in my 720×486 SD projects, when I render a 640×480 approval WMV for my client, I (very frequently) get a couple of video sequences that show through either top and bottom and/or side to side outside of the letterbox TGA file (it’s just a “cover” image to make a 16:9 appearance inside a standard 4X3 frame).
    I’ve tried every possible setting known to Vegas in terms of square pixel, non-square pixel, scale to fill frame, and nothing is reliable enough to know what really solves the problem. I’ve even tried to scale my already 720×486 letterbox image UP so it lives partially outside the 720×486 frame size, but even that doesn’t seem to help. That was my (failed also) “bleed” idea.
    And, to be clear, the image I’m using is the top-most layer.
    Now, the only other thing I can think to describe here is that there only seems to be a problem with either 640×480 WMV output and 720×480 MPG2 output. MOVs at 720×486 look perfect. But, I just find it troublesome to send an approval movie to a client with extraneous garbage showing through the margins of my spots.
    I’d be happy to create an example of what I’m talking about if anyone has any clues, and I sure would love to know what the heck is going on…
    Thanks, as always,
    –Kelly
    Kelly Griffin replied 14 years, 11 months ago 6 Members · 12 Replies
  • 12 Replies
  • Stephen Mann
    September 28, 2011 at 4:29 am
    Post a screenshot.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Mike Kujbida
    September 28, 2011 at 12:38 pm
    Kelly, are your project properties (File- Properties) set to 720 x 486?
    “…the image I’m using is the top-most layer.”
    Open Pan/Crop for each event on this layer, right-click and select “Match Output Aspect”.
  • Bob Peterson
    September 28, 2011 at 1:50 pm
    I’ve had this happen when the still image aspect ratio is a bit off. When that happens, the image leaves either vertical or horizontal gaps that underlying layers can show through. There may be a calculation to find the exact pixel dimensions needed for a particular video resolution, but I usually resort to a bit of trial and error to find a precise setting. I adjust pixel dimensions in Photoshop until I find the setting which works.
  • Kelly Griffin
    September 28, 2011 at 4:45 pm
    Yeah, well, I’m just baffled why if project settings are 720×486 and an image is 720×486 how they don’t fit EXACTLY.
    I’m going to check Mike’s “Match Output Aspect” setting, but I could swear I looked at that as well…
    Harumph,
    –Kelly
  • Kelly Griffin
    September 28, 2011 at 4:55 pm
    Hey Mike, yes, project properties are at 720×486. Letterbox image is also 720×486.
    But, I’ll try what you suggest and hope for the best, thanks.
    –Kelly
  • Matt Crowley
    September 28, 2011 at 5:47 pm
    As a quick alternative to making a still image letterbox mask, you can use the Checkerboard media generator to make the mask.
    Just drop a Checkerboard media generator onto your top track, and set the parameters like so:
    Width: 1
    Height: 0.75
    Edge Blending: 0 Horiz and Vert
    Color 1: transparent
    Color 2: Solid black
    Grid Position: X=0, Y=0.125
    Save that as a preset once you’ve tested it, and stretch it out to the duration of the project.
    Those settings also work for PAL – basically any 4:3 to 16:9 letterboxing I think.
  • Kelly Griffin
    September 28, 2011 at 5:51 pm
    That’s a cool idea, Matt, and I’ll try that.
    But, I guess my bigger issue is just understanding why I’m getting what I’m getting when I’ve never encountered it with other programs before…
    –Kelly
  • Tyson Onaga
    September 28, 2011 at 11:24 pm
    720 x 486 = 1.48
    640 x 480 = 1.33
    Have you tried creating a 640 x 480 project, nesting the 720 project inside of it, and putting a 1.48 pan/crop event at the beginning, and then render?
  • Kelly Griffin
    September 29, 2011 at 1:33 am
    I tried Matt’s suggestion and got the exact same results. I may try Tyson’s idea for approval renders, but I should have been clear earlier that I get the same issue with 720×480 MPG2 renders. Everything’s perfect with 720×486 MOV renders, but I just can’t figure out W-H-Y this is happening. No matter what I’ve tried, Vegas wants to take my letterbox image and shrink it about five or six pixels on the left and right, making the underlayers show through.
    So (I guess), back to my original “bleeding” idea… How can I make a top and bottom black strip that goes wider than 720 (and stays that way during a render), bleeding out past the actual frame size so that fullsize MPG2s and 640×480 WMVs will look correct?
    Thanks… sorry if I’m exasperating to anyone.
    –Kelly
  • Matt Crowley
    September 29, 2011 at 6:50 am
    Kelly, have you got “Adjust source media to better match project/render settings” enabled in the project properties? If yes, then disable that and try the renders again. This option re-frames (crops) some source media to fit the render settings, and seems to only affect some video events for me, not stills – that might explain why you see some media showing through the mask edges.
    Alternatively, try enabling the “Stretch video to fill output frame…” option in the render dialog. That will prevent extra letterboxing by cropping the output video slightly as necessary when you render to a format that’s different to your project settings. There’s a slight quality hit due to the resize, but that’s probably OK for approval/proof videos.
