Activity › Forums › Boris FX › Blank render problem
  • Blank render problem
    Posted by Ken Plotin on April 3, 2006 at 9:10 pm
    Wow, is this frustrating! I built a simple flying text project to test out some style pallette stuff. Added a few lights…everything looks fine in the preview window.
    When I render it (.avi or .tga),I get what looks like an alpha channel: white letters on a black BG. I haven’t changed anything in my prefs, and checked them to be sure.
    What’s goin’ on???
    Any help appreciated.
    Ken
    Ken Plotin replied 20 years, 5 months ago 2 Members · 2 Replies
  • Mark
    April 4, 2006 at 1:38 am
    Make sure that you are set to render the RGB and not just the alpha channel. TRy rendering as a quicktime using the animation codec and set to millions of colours+. This will give you the RGB + Alpha.
    Hope this helps,
    Mark
  • Ken Plotin
    April 4, 2006 at 2:08 am
    Thanks Mark,
    I rendered the file without using lights and it was ok. If I use lights (in any configuration) the white letter/black BG problem on rendering occurs.
    I’ll try the quicktime output and see if that makes a difference.
    Thanks again,
    Ken
