Activity Forums Storage & Archiving Blackmagic speed test suggestions…
  • Blackmagic speed test suggestions…
    Posted by Fabrizio D’agnano on December 22, 2017 at 11:35 pm
    Hello.
    I am about to buy a new RAID on a very small budget. I currently own a USB3 Proavio loaded with 5 WD Red 3TB drives, that seems to have some problem. I can’t get it to read or write over about 130 mbps either in RAID 0, RAID 5 or anything, which is slower than a single drive (I tested it the same way and it was surprisingly faster, as was a software RAID 0 made with two of the same drives on an external USB 3 dock, over 250 mbps). It’s full about 30% of total capacity. Every now and then it slows down to 35 mbps, until I restart the Mac, but the very same happens to even SSD’s, that are sometimes very fast, sometimes 35mbps , so I gather it is a double problem. Something is going weird with maybe the controller on the large RAID (it used to be able to read and write over 200 mbps), something with the USB3 of my old 2013 MBPr, So I thought I might be better off with a new Thunderbolt RAID. I edit mostly 1080p from AVCHD or XAVC, 50 mbps, and some 4k from a JVC camera and Mavic Pro drone. Max 100 mbps. Plain documentary style, max three streams and some filters like color correction, resize, nothing too heavy, about 12 to 24 minutes projects. When reading the Blackmagic speed test, it seems that 100 MBps only allows one stream of 1080p, maybe not even all frames, while the math I know would suggest about ten streams. When I’m on site and build the rough cuts on a single external USB 3 drive I usually don’t experience any serious problem. So if I look at budget and personal experience, I’d buy a two drive RAID 0 unit like Lacie 2big or G-RAID, keeping the current RAID 5 as a backup and archive, of course with other copies on single drives, while if I follow Blackmagic speed test suggestions I should go for a much faster drive, like a Thunderbolt RAID 5 with four drives or more. How much speed is really needed?
    Fabrizio D\’Agnano
    Rome, Italy
    Fabrizio D’agnano replied 8 years, 8 months ago 2 Members · 6 Replies
  • Rainer Wirth
    December 23, 2017 at 11:09 pm
    Hi Fabrizio,
    what computer do you own?
    What is your raid connection?
    Do you have a thunderbolt connection within your computer?
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Fabrizio D’agnano
    December 24, 2017 at 9:16 am
    Hi Rainer.
    I currently own a late 2013 MBPr 15″, so I can use two TB2 connections. The USB3 ports have always been someway unreliable, with drives randomly dismounting, more often during long copies or backups, variable transfer speed etc. Using the drives or arrays via the USB3 on my Belkin TB adapter was often tricky because it sometimes took several efforts to have the drives recognised, and transfer speed was slower than direct connection. That’s why I was thinking about going for the TB connection. As I wrote, I am currently running a very low budget, so I was wondering if a 2 striped drives small array like Lacie 2Big or G-Raid would be enough, or if a larger setup like a Pegasus R6 was convenient. Until last year I only edited 1080i or 1080p, but I am adding some 4k media.
    Thank you!
    Fabrizio D\’Agnano
    Rome, Italy
  • Rainer Wirth
    December 28, 2017 at 9:49 pm
    Hi Fabrizio,
    TB 2 is fine.
    You need a raid array with a minimum of Raid5 level, better Raid6.
    A two bay raid won’t give you this.
    You need at least a 4bay Raid.
    The 6bay is ideal – also with 4k in mind.
    cheers
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • Fabrizio D’agnano
    December 29, 2017 at 5:04 pm
    Thank you very much, Rainer.
    Your suggestion for a larger RAID5 is more for safety while working (I know that a RAID5 is not a backup) or speed? I am used to synch and backup the projects I’m working on onto two different sets of slower drives at noon and at evening, so what I’d loose in case of failure is a couple of hours of work, four at worst, that is not deadly in my case. That would balance the at least 1.000,00 Euros of price difference between a two drive RAID 0 and a Promise Pegasus r6. Real need for more speed would of course change everything and push me towards the larger and faster and more expensive set, and that’s why I was wondering if about 250 MB/s like a two drives set would offer would or not be enough for editing two or three streams of 50 to 150 mbps footage.
    Fabrizio D’Agnano
    Fabrizio D\’Agnano
    Rome, Italy
  • Rainer Wirth
    January 1, 2018 at 12:59 pm
    Hi Fabrizio,
    You need roundabout real 450-500 MB/s speed, especially if you work with 4k..
    cheers
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • Fabrizio D’agnano
    January 1, 2018 at 6:09 pm
    Thank you again!
    Fabrizio
    Fabrizio D\’Agnano
    Rome, Italy
