Activity › Forums › Apple Final Cut Pro Legacy › BlackMagic Speed Test Error
  • BlackMagic Speed Test Error
    Posted by Blackstonefilmworks on February 4, 2006 at 6:16 pm
    Good day.
    I recently picked up a Mac G5 PCI-X 2.3 system. I installed a Decklink SP card plus 4 250gb 8 cache Maxtor SATA drives all plugged into a Sonnet tempo x 4×4 card in the 133 slot. When I followed the disk utility set up for a striped raid0 mac os extended (journaled) the “slices” show up on my desk top as one drive with a 930.79 GB capacity.
    All seems fine. I transfered over my project files and all show up and FCP 5 seems to run fine. I had originally captured the footage from Betacam SP over to BlackMagic NTSC DV codec as I first was on the internal 400 GB drive prior to adding the internal raid. Now with the raid installed and mounted, I’ve switched All settings over to 10 bit NTSC. That’s some background.
    Now when I decided to run BlackMagic Speed Test the first go at it gave me the spinning pin wheel of death for about 15 mins or so ( until I got fed up) and I did a force quit. I then tested the HD and that took only seconds, so I tried the raid again and I get “DISK ERROR Could not run disk test” with no options or available additional info to be found.
    I admit that I’m quite new to all this, previously I had used an Avid ABVB9000 AVR77, which either worked or it didn’t. It seems this FCP is a bit more complicated, but then again – I’m easly distracted by shiny objects.
    Any thoughts or help regarding this issue (I’m working on the shiny objects one on my own) would be great.
    Cheers
    Tom
    Frank Nolan replied 20 years, 7 months ago 3 Members · 2 Replies
  • David Roth weiss
    February 4, 2006 at 7:48 pm
    [BlackstoneFilmworks] “It seems this FCP is a bit more complicated”
    Tom,
    To the contrary, FCP is incredibly simple. Something is wrong with your hard disk subsystem. If you still have the media on your old hard drive I would go into disk utility and start over again. Erase each drive individualy and then restripe at raid-0, this time with no journaling. If that is a problem, then its possible that your Sonnet controller has issues with those Maxtor hard drives.
    DRW
  • Frank Nolan
    February 5, 2006 at 12:14 am
    [BlackstoneFilmworks] “I had originally captured the footage from Betacam SP over to BlackMagic NTSC DV codec as I first was on the internal 400 GB drive prior to adding the internal raid. Now with the raid installed and mounted, I’ve switched All settings over to 10 bit NTSC”
    When you say you switched over to 10 bit NTSC, what do you mean? Did you re-capture the footage as 10bit or did you just change your sequence settings?
    As David said go back into the disk utility and erase and reformat the drives one by one as mac os extended (NOT JOURNLED). Then drag them all to the box to re-stripe the raid also NOT Journled.
