Activity Forums Blackmagic Design Blackmagic Software Crashes Premiere 3.2
  • Blackmagic Software Crashes Premiere 3.2
    Posted by Frank Ruggiero on November 24, 2009 at 3:19 am
    Hi Blackmagic,
    Has anyone had this issue? I am on Macintosh OSX 10.5.8. I installed the Blackmagic software 7.3.2, and it seems to crash Premiere. It wont allow me to play any clips. As soon as I uninstall it, Premiere works fine. I have tried installing Blackmagic 7.2.1 and it does the same exact thing, I get the beachball and it freezes. As soon as I uninstall, it works fine.
    I do not have the card installed yet. I wanted to test before I purchase the Blackmagic SDI card.
    If anyone can shed some light on how I can get this to work, that would be great. I am trying to buy a monitor and card, but I want to make sure this all works correctly before I purchase.
    Thank you.
    Frank
    Frank Ruggiero replied 16 years, 10 months ago 2 Members · 2 Replies
  • Joshua Helling
    November 25, 2009 at 8:14 pm
    Are you using our easy setups in Premiere without the board installed?
    This should not cause problems, but it might be something to look into as potentially the application is looking for our board for I/O and it is not present. Can you confirm if these issues happen while NOT using a BMD preset?
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • Frank Ruggiero
    November 26, 2009 at 3:34 am
    Hi Joshua,
    Thanks for responding to my post. You are on to something. Indeed, Premiere only crashes when I use a BMD preset. If I set up my own custom project setting, it works fine.
    Do you think once a BMD I/O card is installed, I will be able to use the Blackmagic easy setups without crashing?
    -Frank
