Activity Forums Blackmagic Cameras BlackMagic raw dng not sync with audio
  • BlackMagic raw dng not sync with audio
    Posted by Tada Chen on April 21, 2016 at 1:01 pm
    Hi I have a problem about the dng sequence and the audio(wav). Shooting in 25fps. The audio has one more frame than dng sequence which means the dng sequence is 00.00.49.10 the audio would be 00.00.49.11. Do you guys know why?
    I know audio is not count by frames but when I drag the audio to the timeline it has one more frame longer
    John Mahoney replied 10 years, 4 months ago 2 Members · 1 Reply
  • John Mahoney
    May 2, 2016 at 10:46 pm
    Can you play the vid/audio out of the camera and see if it drifts out of sync? Or is it only in your edit system that it loses sync?
