Activity Forums Blackmagic Design Blackmagic projects and DV projects in the same system (windows)
  • Blackmagic projects and DV projects in the same system (windows)
    Posted by Manololp on March 20, 2007 at 1:46 am
    Hello. This is my experience (sorry for my English):
    1) Print to tape (by firewire) of DV projects is only possible if a blackmagic projet is not loaded before. If a blackmagic project is open, then a reboot is necessary. For smooth playback (on DV tape) of blackmagic clips, the remove flicker option (in Premiere timeline) is necessary for that clips.
    2) The best option is to use always a blackmagic Pal 8 bit YUV project, and to capture by decklink card or DV (firewire): the external monitor is used in the editing process. For to export this project to tape by firewire, import it in a DV (no blackmagic) project.
    I hope this help.
    Regards
    Manuel Lopez
    Decklink Extreme PCI 5.8
    Asus P5B Deluxe
    Core 2 Duo E6600
    Nvidia 7600 GS
    2 Gb Ram
    1 TB raid 0 (200 Mb/seg write)
    Manololp replied 19 years, 6 months ago 2 Members · 4 Replies
  • Baz Leffler
    March 20, 2007 at 11:07 pm
    You can also use the Decklink card as an external monitor in a native Premiere DV project.
  • Manololp
    March 21, 2007 at 2:29 pm
    Hello. How?
  • Baz Leffler
    March 21, 2007 at 11:55 pm
    How? Well OK but this is only for you so keep it a secret…
    1/ Open a new PPro 2 project
    2/ select the ‘custom’ tab
    3/ select DV PAL (or NTSC) from the drop downs
    4/ click on ‘playback settings’
    5/ in ‘external device’ select the BMD device (will show as a monitor number)
    6/ set everything else as necessary
    7/ save it as a preset for future use
    The above will create an XML file in the edit preset folder of PPro.
    Baz
  • Manololp
    March 22, 2007 at 12:44 am
    Oh
