Blackmagic Presets Premiere CS3 Windows
Hello,
Some questions..
Why aren’t there P2 blackmagic presets in the Blackmagic folder and are only accesible through the custom panel?
I’ve noticed when editing a custom Preset with settings:
Editing mode: Blackmagic P2 720P 50Hz DVCPROHD
Timebase: 25,00 frames/second
(For 720 25pn MXF Files-HVX200 which is the correct setting)…And previewing through s-video in sd TV, the image seems absolutely distorted and black and white.
Now, if I close the project open a new custom one and set the timebase for 50,00 frames/second, the image is displayed just fine, But the timebase is wrong and it is impossible to properly work in it with files that are 25fps and are manipulated as such, in mixing etc…Why aren’t there plain BM DVCPRO-HD setups for capturing from e.g a DVCPRO-HD deck, or do the P2 setups function properly for this type of capture? Cause I’m planning on renting an HDX900 or Varicam.
Thank you.
