Activity Forums Blackmagic Design BlackMagic Mulitbridge Pro “No Video Input”
  • BlackMagic Mulitbridge Pro “No Video Input”
    Posted by Lance Cooper on January 7, 2008 at 3:26 pm
    I’ve just had some fixes done to my Quad G5, and now the Multibridge only gives me the “no Video Input” on all of the different inputs (YRB, NTSC, SDI). I’ve tried reseting the card, but nothing seems to help yet. My External SATA raid is also not working. I am wondering if when it went in for repairs if the cards were put in the wrong slots.
    Here’s what’s been done. Clean System Install, Reinstall of the Drivers 6.4, OS 10.4.11.
    Anyone know of anything I may be missing or that can help?
    Lance Cooper replied 18 years, 7 months ago 2 Members · 2 Replies
  • Kristian Lam
    January 8, 2008 at 1:00 am
    Hi Lance,
    What about video input formats? Did you use the right easy setup in Final Cut Pro or Blackmagic Deck Control?
    The fact that it showed the “No Video Input” message meant that the hardware is being seen by the Mac. It’s possible that the Multibridge was sent a different signal than what it was expecting.
    regards
    Kristian Lam
    Blackmagic Design
  • Lance Cooper
    January 8, 2008 at 2:34 pm
    I’ve tried YRB, HD SDI, and straight NTSC all through the easy setups in Final Cut. I’ve changed settings in the system preferences too. But no luck. I’ve also switched cables and no luck. I tested the sources and they are outputting video. Any other ideas or things I might be missing?
