Blackmagic mp4 Vegas Pro
Posted by Ross Stark on March 8, 2022 at 2:58 pmI have recorded a few things with my BMD Extreme ISO, and I am unable to pull the resulting mp4 files into Vegas Pro 14. I can play the files on my computer in “Movies & TV” and in VLC.
Is there a codec I need to import or something?
Ross Stark replied 4 years, 6 months ago 1 Member · 1 Reply -
1 Reply
Ross Stark
March 8, 2022 at 3:22 pmFile info from MediaInfo for the file I’m attempting to import:
General
Complete name : D:\Projects on laptop\FBC Christmas 2021\Video Import\FBC Christmas 2021.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (iso4/avc1/isom)
File size : 3.33 GiB
Duration : 1 h 20 min
Overall bit rate mode : Variable
Overall bit rate : 5 937 kb/s
Encoded date : UTC 2021-12-04 23:57:46
Tagged date : UTC 2021-12-04 23:57:46
Writing library : Apple QuickTime
com.blackmagic-design.camera.dateRecorde : 2021:12:04
com.blackmagic-design.camera.timelineID : c15a7b2c
com.apple.proapps.clipID : FBC Christmas 2021
com.apple.proapps.cameraName : 0
com.blackmagic-design.camera.uuid : 63778A7549344DD7BC364FBD8798AD-0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 5 805 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.093
Stream size : 3.25 GiB (98%)
Language : English
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Audio
Format : mp4a
Codec ID : mp4a
Source duration : 1 h 20 min
Source_Duration_LastFrame : -16 ms
Bit rate mode : Variable
Bit rate : 128 kb/s
Stream size : 73.5 MiB (2%)
Source stream size : 73.5 MiB (2%)
Language : English
Other
Type : Time code
Format : QuickTime TC
Time code of first frame : 17:57:46:12
Time code, striped : Yes
Language : English
