Activity Forums Blackmagic Design Blackmagic LiveKey and Final Cut Pro alpha channel problems
  • Blackmagic LiveKey and Final Cut Pro alpha channel problems
    Posted by Thomas Berglund on February 13, 2008 at 8:21 pm
    Hi!
    I am using Final Cut Pro to output graphics with an alpha channel (Animation, millions of colors+), with the help of LiveKey through a Multibridge Pro.
    The Video Out in FCP has to be set to Blackmagic RGB for this to work, but it only works while the timeline is playing over a clip. Every time you pause or the playhead is over an empty video track, the alpha channel (matte) is broken.
    How can I fix this? I would like to be able to pause, without destroying the alpha. Any suggestions?
    Thomas Berglund
    Thomas Berglund replied 16 years, 8 months ago 2 Members · 2 Replies
  • Callum Macmillan
    August 26, 2009 at 3:42 pm
    Hi Thomas did you solve this problem?
    I’m trying to do the same thing and am only having success with Livekey & Qclip. I’m only getting full frame white key from FCP with Livekey.
    Best Wishes
    Callum
    http://www.timeslicefilms.com
  • Thomas Berglund
    August 28, 2009 at 11:25 pm
    I actually managed to get it right through Apple’s Motion 2.0, with video out set to BMD RGB. It did not work properly in Motion 3 or FCP.
    Blackmagic Design had actually never heard of LiveKey being used in conjunction with FCP
    before I asked them questions about it, back in February 2008.
    I would definitely look for an other more reliable solution.
