Activity Forums Blackmagic Design Blackmagic Intensity Shuttle dont work
  • Blackmagic Intensity Shuttle dont work
    Posted by Danny Friedrich on May 15, 2011 at 7:35 am
    Hello,
    I have the Blackmagic Intensity Shuttle and i connect my xbox 360 with this.
    I want to record in 1080i and with media express or virtualdub.
    I have a HDMI splitter between my Tv, Xbox 360 and the Shuttle, but i have the problem that when I record i have less than 1 second a black screen in the video several times.
    btw I have a x58 motherboard and 2 usb 3.0 slots.
    and sorry for my english i am from germany
    Danny Friedrich replied 15 years, 2 months ago 3 Members · 5 Replies
  • Kristian Lam
    May 16, 2011 at 1:10 am
    Hi Danny,
    The first thing I would try is to remove the HDMI splitter from the setup. Connect the Xbox output directly to the Intensity Shuttle and see if that helps.
    regards
    Kristian Lam
    Blackmagic Design
  • Danny Hays
    May 16, 2011 at 2:00 am
    Also are you capturing as MJPEG or 8 or 10 bit uncompressed without a raid array? That would couse you to drop frames. I would use the disc speed utility included and see if your drive can handle the I/O.
  • Danny Friedrich
    June 10, 2011 at 6:19 pm
    Ich habe schon alles versucht sowohl xbpx 360 als auch die ps3 funktionieren nicht richtig habe 3 festplatten als raid 0 angeschlossen habe im disk speed test von blackmagic 330 mb/sec lese und 350 mb/sec schreib geschwindikeit und die schwarzen bildschirem erscheinen weiterhin die platten wurde auch als speicher ausgewählt dür media express
  • Danny Friedrich
    June 12, 2011 at 5:38 am
    I’ve tried everything. xbox 360 and the ps3 will not work. I have 3 hard drives connected as RAID 0. I have read in the disk speed test of black magic 330 MB / sec and 350 mb / sec write SPEED. but the black screen still appears. the hard drives were also selected as the storage media for express. I have tried all possible settings. No matter if I am in it with HDMI or analog.
  • Danny Friedrich
    June 12, 2011 at 5:39 am
