Activity › Forums › Blackmagic Design › Blackmagic Intensity Pro Driver Problem
  • Blackmagic Intensity Pro Driver Problem
    Posted by Joey Chilson on August 30, 2011 at 4:06 pm
    I’m having a problem with getting my Intensity pro working. I placed the card into the PCI slot in the back of my computer. I turn it back on and install the latest driver from online. I believe it’s 3.5. The installment completes and it ask me to restart so I do. When Windows boots up you can till there is an audio lag. The start up sound is laggy. I log in and when I move the mouse it lags across the screen and basically Windows is all laggy. It then ask me too update firmware and I click install and it doesn’t. I get an error and I restart my computer and it doesn’t shut down. It gets stuck on the “shutting down…” screen and I’m forced to hard shut down. I restart my computer up and disable both Audio and the basic driver and restart and the computer is back to normal. So it’s something with the driver I believe.
    This is Windows 7 64 bit.
    Any help would be amazing.
    P.S I worked for like 5 sec before then start the lag again.
    Daniel Jones replied 14 years, 9 months ago 3 Members · 4 Replies
  • Paolo Castellano
    August 31, 2011 at 3:03 pm
    Hello Joey,
    be careful with hardware compatibility. Driver 3.5 is out of date (replaced by desktop video 8.x, with 8.5 as the last available build), but I had no problems in the past with v.3.X
    Best Regards,
    Paolo
    Paolo.Castellano@ivs.it
    http://www.ivsEdits.com
    “Post Fata Resurgo”
  • Joey Chilson
    September 3, 2011 at 12:38 pm
    I have tried the latest drivers and I have the same problem.
  • Daniel Jones
    December 26, 2011 at 9:31 pm
    Hey my computer is having the same exact problem, did you ever find a solution for it?
  • Daniel Jones
    December 26, 2011 at 9:35 pm
    I have had the same problem too, Have you figured at a solution?
