Activity › Forums › Blackmagic Design › BlackMagic Intensity Pro – Blackscreen
Posted by Brendan Smith on March 22, 2011 at 3:25 amI made a video describing my problem.
https://www.youtube.com/watch?v=X49Rp1jwJt8&feature=channel_video_title
But if you don’t wanna watch, basically the input/output is not working in Media Extreme. I am really excited to start using this product, so I need this problem fixed.Johnnie Baker jr replied 15 years, 5 months ago 4 Members · 4 Replies -
Scott Francis
March 22, 2011 at 12:03 pmDid you go to the Blackmagic settings and pick the inputs you desire…it is under control panels…I made a shortcut onto my desktop for mine..good luck!
Scott Francis
Mind’s Eye Audio/Video Productions -
Chris Pearse
March 22, 2011 at 12:24 pmHi Brendan,
It looks like you have everything connected up properly. Typically the most common issue is the settings. Media Express, or whichever capture application you may use, will need to be set to capture the same format the source device is outputting. The Xbox 360 seems to default to either 1080i59.94 or 720p59.94 in my experience. I would try these first. I would suggest making sure that the capture format is set correctly in Media Express by going to Edit->Preferences->Project Video Format, and changing this accordingly.
You should find that once you’ve hit the right setting, you’ll get a picture on the HDMI output, and in the preview section of Media Express. If you don’t get any picture in Media Express, often this is down to the graphics card drivers. Typically downloading and installing the latest graphics driver from the manufacturer is the best idea in this case.
if you still need help however, please do get in contact with your regional support office. You can send a support request using the form here:
https://blackmagic-design.com/support/contact/
You can also find the support numbers for each office here:
https://blackmagic-design.com/company/
Chris Pearse
Technical Support Consultant
Blackmagic Design EMEA -
Johnnie Baker jr
March 31, 2011 at 5:15 pmMy hd camera outputs at 601 and captures in the blackmagic card at 59.4. How do i it get the footage back to native 24p?
