Activity Forums Blackmagic Design BlackMagic Intensity output in After effect
  • BlackMagic Intensity output in After effect
    Posted by Jonathan Desbiens on June 14, 2008 at 7:00 pm
    HI!
    I work with a NTSC/DV composition in aftereffect and my video preview setting is set at Intensity NTSC/more accurate quality.
    Even if my resolution is at FULL…the video playing in the screen still pixelate..
    Do I need to active something to see the final result/preview quality on the screen during playback?
    Pixel aspect ration problem?
    Jonathan
    Marcel Thibault replied 11 years, 7 months ago 4 Members · 4 Replies
  • Yuhsiao Yu
    September 16, 2008 at 2:44 pm
    exactly the same problem I am facing.
    or it is only video “preview”.
    I am dealing with ntsc interlace footage. pixelated video preview …. too bad….
    anyone can help? or suggest a way workaround …
    great thanks
  • Alex Rodriguez
    September 23, 2008 at 12:01 am
    I have the exact same problem. I finally got my intensity card to work with my system after a lot of headaches and now my display is not right. I’m using a Sony Bravia HDTV to preview SD and HD material. Premiere displays images with no problem, very happy there. But After Effects which is my main aplication will not. HD looks a little pixelated, but SD material look horrible half resolution at best but After Effects is set at Full resolution. I have not idea what to do. Help!
    Alex R
  • Alex Rodriguez
    October 21, 2008 at 9:07 pm
    Just thought I let you know I solved my problems a while ago. I went to widows control panel and there you have an intensity settings icon. It is here that you can tweak the cards main settings. after trying a few setting… no more blurry screen and real time preview for mos formats is restored. hope this helps
    Amd Dual Opteron 2.2
    Quadro 4500
    xp Pro
    Tyan Thunder Mobo
  • Marcel Thibault
    January 26, 2015 at 12:33 am
    Hello,
    Go to Control Panel
    Go to Balckmagic Design Control
    Uncheck “Remove Field jitter…”
    Marcel
