Activity Forums Blackmagic Design Blackmagic Intensity Downconversion
  • Blackmagic Intensity Downconversion
    Posted by Rivai Chen on February 22, 2012 at 7:29 am
    hi guys
    I just get my Blackmagic Intensity for H.264 offline purposed. Everything works great. H.264 monitoring straight from Premiere Blackmagic dSLR timeline.
    There’s one obstacles that i hope blackmagic can answer here. Does downconversion (Composite Y-out) works in this dslr mode ? I tried so many times, but it doesnt work. Is there any ways to make it work ? Or this is the technical limitation
    Rivai
    Rivai Chen replied 14 years, 7 months ago 2 Members · 2 Replies
  • Kristian Lam
    February 23, 2012 at 2:43 am
    It depends on what format your output video is. The down conversion works with 1080i59.94 and 720p59.94 to get NTSC, 1080i50 and 720p50 to get PAL output.
    Is down conversion selected in the Blackmagic control panel?
    regards
    Kristian Lam
    Blackmagic Design
  • Rivai Chen
    February 23, 2012 at 4:11 am
    Everything works except dSLR timeline, it failed to output analog output. Other mode is totally fine..
    The selected preset is blackmagic dslr 1080P 25, the hdmi output is working fine. But no display on pal analog output. Downconversion in output processing blackmagic control panel is selected.
    I tried on blackmagic decklink extreme, same result. Dslr timeline no good on analog output. Is this supposed to work ? Or not ?
    Rivai
