Activity › Forums › DaVinci Resolve › Blackmagic Impresario Panel
Posted by Aurie Anden on August 16, 2010 at 11:10 amHi. Is anyone aware if there is a manual out for the Resolve on the Impresario Panel?
Courtney Feemster replied 13 years, 3 months ago 5 Members · 4 Replies -
Joseph Owens
August 16, 2010 at 11:35 pmThe only control panels qualified to function with BM Resolve are the Tangent Wave and DaVinci Resolve dedicated panel. The Wave will only work with the Mac version, and the Linux version requires the DaVinci control panel.
Just because something is a Blackmagic product does not mean that it is qualified to function with all other Blackmagic products, this application in particular.
jPo
You mean “Old Ben”? Ben Kenobi?
Dwaine Maggart
August 17, 2010 at 1:29 amJust to clarify: Impresario is no longer available. What was the Impresario panel set has been redesigned by BMD, and is now called the Resolve Control Surface.
A new manual for Resolve, including the Resolve Control Surface is being worked on. I don’t know what the current release estimate is for the manual, but maybe Peter can chime in with an estimate.
Dwaine Maggart
Blackmagic Design DaVinci Support -
Luke Maslen
August 27, 2010 at 2:19 amHi Aurie,
Yes, the Impresario information is still available in the old Resolve manual. Please download the PDF and then search it for the phrase “control surface”. Any reference to the DaVinci Control Surface or Resolve Control Surface is referring to the previous Impresario panels which connect via ethernet networking. You can download the PDF from https://www.blackmagic-design.com/downloads/davinci/pdf/DaVinciResolveManual.pdf
Resolve v7.0 for Linux will continue to support the Impresario and 2K panels as well as the new Resolve Control Surface which connects via USB.
Regards,
Luke Maslen
Blackmagic Design -
Courtney Feemster
June 3, 2013 at 5:12 pmHi Luke,
I have the old Impresario Panels for Resolve. I am currently using Resolve 9.0.3 (mac) and I cannot get the Resolve to recognize the panels. The panels power up and before I stopped using them about 3 years ago they worked perfectly fine. I imagine it is a firmware issue but how can I get the panels firmware to update if the program won’t even recognize the panels. These were originally used on a Linux platform.
-Courtney
