Activity Forums Blackmagic Design Blackmagic HDlink – RAM
  • Blackmagic HDlink – RAM
    Posted by Pieter Smet on August 29, 2012 at 11:00 am
    Hello,
    I had a small problem with my macpro today. He didn’t startup because of bad ram. So I took 1 dimm out.
    After doing that, the computer did his job.
    But now I have a video problem.
    I have a Blackmagic HDlink connected to the Mac, and an Eizo monitor connected to the HDlink. When I open FCP now I get a really bad image, like some kind of negative, with lots of colors.
    Is this due to the ram issue?
    Sean Donnelly replied 14 years ago 3 Members · 2 Replies
  • Chris Pearse
    August 30, 2012 at 7:55 am
    Hi Pieter,
    I think it’s unlikely to be a problem with the RAM. Is this an HDLink connected between the Eizo monitor and a DeckLink card?
    The description of it as negative makes me think it could be a dual-link SDI problem. Maybe if you were using dual-link SDI it might be only displaying one channel. In which case, please check both SDI cables.
    If you are not using dual-link, maybe the output from your Mac is set to dual link. If you have a DeckLink card for example you can disable dual-link in the Blackmagic section of System Preferences. If using FCP7 Please check the settings under View->Video Playback. If it’s set to an RGB codec, try changing it to YUV.
    If using an HDLink will also have Lookup Tables which you can apply to it’s outputs to change it’s look. I would suggest connecting the HDLink to a computer by USB, and launch the HDLink Utility, and press the ‘reset unity’ button. This should clear any possible bad colour settings.
    If you still have problems I would suggest contacting support to troubleshoot the issue further.
    Chris Pearse
    Blackmagic Design
  • Sean Donnelly
    September 10, 2012 at 12:22 pm
    I’ve seen this with several of my HDLink boxes. As Chris suggested all you have to do is load the utility and make an adjustment (resetting works well).
    -Sean Donnelly
    Local 600, DP/Colorist
    -Sean Donnelly
    Digital Supervisor, SFI
