Activity Forums Blackmagic Design Blackmagic DV capture – with FCP
  • Blackmagic DV capture – with FCP
    Posted by Xtothed on November 27, 2005 at 4:54 pm
    Hi There,
    This is kinda a Blackmagic and FCP question.
    I have Decklink SP – and usually capture in 8 or 10 bit uncompressed. But sometimes I want to capture in using the Blackmagic DV setting – which was set up for me by the company I bought the G5 from.
    Capturing using the card is fine – but when I drag that onto my FCP timeline it needs rendering – which obviously I dont want.
    I know I have to change my timeline settings in FCP (Audio & Video Settings) but no matter what I seem to change it to it still needs rendering. Does anyone know what FCP settings I need – I have duplicated the Blackmagic 8bit uncomp setting, then changed it to a DV codec but that doesnt seem to work? Any ideas?
    Cheers
    Xavier
    PS – All this is in PAL, 16:9
    Jason Levy replied 20 years, 10 months ago 5 Members · 4 Replies
  • Steve Connor
    November 27, 2005 at 8:54 pm
    New project, use the Blackmagic DV PAL easy setup and it should just work – it does on our system.
    Steve Connor
    Cardinal HD
    Please fill in your profile – it helps US to help YOU!
  • Trevor Kinsey
    November 28, 2005 at 1:11 am
    You might need to change the field order on your timeline as well. Depends on what standard you are using (NTSC/PAL).
    Trevor Kinsey,
    Technical Producer,
    CVP Film and Television,
    Melbourne,
    Australia
  • Kristian Lam
    November 28, 2005 at 2:53 am
    Hi Xavier,
    Steve is right. Just use one of our easy setups. Make sure you’re dragging the captured clip to a sequence created [b]after[/b] choosing the easy setups.
    If you want to output the DV clip captured using our easy setups to your deck/camera via firewire, then rechoose the Apple DV – PAL setup and drop the captured clip in there.
    regards
    Kristian
    Blackmagic Design
  • Jason Levy
    November 28, 2005 at 3:00 am
    A long-shot here.. One “gotcha” that you have to remember: when you chance the easy settings to DV be sure to create a new sequence afterwards. Changing the easy settings does not change sequences that are already in existence..
    hope that helps.
    jason
